![]() | Home > General (L405) > Start stop technology |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626 ![]() ![]() |
£20k premium over an SDV8 Vogue should disabuse them of that notion.
5.0 Member Since: 25 Feb 2012 Location: Surrey Posts: 721 ![]() ![]() |
Most of that premium us due to the hybrid only being available in AB trim at the moment. That will change. |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
I wouldn't have thought that LR won't just drop the sdv8 without some viable alternative. The v6 is a fine engine but that model is a different beast altogether with no active suspension options etc. it is very unlikely that they will suddenly start to sell the hybrid in the same quantities the sdv8 so I would have thought some viable alternative will be in the pipeline at the new engine plant ready for the change over. Agueroooooooooo. 93-20
Extra weight, additional complexity, unproven reliability (how long has it been delayed?), no performance advantage and a price premium at the same trim level. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
I have a rental VW Golf just now with it. I turn it off as it's a real liability, especially in rush hour traffic. Imagine the scene. You're draw up at a roundabout, brake and the car turns itself off as you sit and wait for a gap in the (almost constant) traffic coming onto said roundabout.
Autobiography Member Since: 10 May 2011 Location: UK Posts: 926 ![]() ![]() |
Mercedes-Benz system works great. Even holds you at traffic lights /in traffic etc with no feet on the pedals. When you depress the accelerator, engine is started, brakes are released and you're on your way! Wish LR had rights to 'HOLD'. |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
The TDV8 is 200kg heavier than the TDV6. That's a lot of batteries. |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
The most annoying thing about turning the S_S off is the fooking bright orange light on the dash |
Hybrid is slightly lighter than the V8 diesel. Plus the weight of the batteries is in the right place rather than strung out over the front axle. Granted, the technology is relatively new and adds conplexity but one has to progress ![]() |
I agree. However, the lack of adaptive dynamics is a bit of a pain I feel.
Would rather go for a stronger V6 and forgo the battery weight. If BMW can make the N57S ... |
Dynamic Response? Not sure. It's described as an optional feature in some LR literature (which then goes on to say it isn't available on the Hybrid). Hybrid can only tow 3000kg too. |
Agree, this is the main drawback. The Sport Hybrid has it though so it should be compatible. |
Flugplatz Member Since: 27 Feb 2014 Location: Cornwall Posts: 75 ![]() ![]() ![]() |
Interesting...
