![]() | Home > Maintenance & Mods (L322) > Wood! |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
Jury's out for me on the cherry wood. I can live with it I suppose, but would've much preferred zebrano (was that even an option on the L322?), lined oak or piano. Can't justify £450 changing something I can live with!
So literally plastic primer gloss black and lacquer? Any chipping issues, has it survived a kid test? My Previous RR's!
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Would you allow your kids to play on yer bonnet Hoppy? |
jeffw Member Since: 18 Jan 2015 Location: Paddock Wood Posts: 60 ![]() ![]() ![]() |
I assumed they where rubbed down, primed and then several coats of gloss/laquer. They look the same as factory Piano Black now. 2011 4.4 TDv8 Vogue SE
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
surely you'd do what I did, buy a rough set of boring coloured (grey in my case) and get them sprayed, and deep polish. then consider the finish, and then set about the changeover, then, presto, your money back on sale of old set... (sort of) or return if 'not sure' |
^ sounds like a better plan sir... |
NeinFondue Member Since: 05 Dec 2014 Location: Berkshire Posts: 22 ![]() ![]() ![]() |
Only potential issue with having them spray painted and lacquer coates is you lose the RANGE ROVER lettering on the door panels.. |
Spare set sounds like a good plan in principle. Finding one on fleabay could be a challenge. I'm not aware of any Range Rover lettering?? My Previous RR's!
You can see the lettering in this picture..
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69 ![]() ![]() |
Zebrano would be nice. Wonder if you can get it 'wrapped' - wheeler dealers did it with a carbon fibre look? |
Get a roll of fablon from the pound shop |
