![]() | Home > In Car Electronics (L322) > Loud buzzing noise through speakers |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
loose wire to one of your door speakers or bad connection/crud on your plug in into amp in rear. |
iantait Member Since: 19 Feb 2015 Location: Essex Posts: 3 ![]() ![]() ![]() |
Hi Dolphinboy
If the wire is touching something else - yes |
They may have pulled a wire out of the connector in the door card and then it touches something else inside the door (possibly metal) and then causes a short. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16391 ![]() ![]() ![]() |
Does your car have LED door handle/door bin lights and do they work? Believe it or not the plug that feeds the power to them is the same plug as the midrange speaker!
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
does your vehicle have DAB? Cheers
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35795 ![]() ![]() |
his 2003 doesnt have DAB... ... - .- -.
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
I have the same problem, but for me it is the dash dimmer switch tun itup and the speaker in the left rear door buzzes away, turn the dimmer switch down no noise and speaker works as normal, just the usual electrickery, Oh yes but this only happens when i turn on the lights.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Occasionally get a buzzing from the odd sounder. Happens once every 6 months or so. There is nothing that can't be fixed with a hammer😜😜
Hi Everyone
cheers, i didnt know what year it came in there is a tech Bulletin related to buzzing through speakers from DAB fitted vehicle. fix is to change the country! Cheers James |
Nilrem Member Since: 17 Aug 2014 Location: Portsmouth Posts: 7 ![]() ![]() ![]() |
I had this on mine and as Craig said the previous owner had connected the 12v feed for the handle/door bin lights to the speaker. The plug is identical to the speaker feed and once disconnected all was well ![]() |
