Home > General > Overfinch L322 - what's this then?
DavidL
http://www.pistonheads.com/classifieds/use...hp/3713058
I thought new OF were bodykits and wheels but this suggests engine work too. The model number certainly apes the old 570/630 ones that OFII did when they put chevy stuff in classics and P38s.
I quite like it but I'd want a "proper" OF car not a tarts boudoir! Depends which it is.
Post #313707 19th Feb 2015 5:36pm
The 580S had engine work & was quite tasty - but it was 10 years ago......
I think they still do re-maps, but nothing that you can't get elsewhere.
Post #313709 19th Feb 2015 5:45pm
See here
http://www.dailymotion.com/video/x7x13_ran...k-320_auto
And it should give you some idea. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #313710 19th Feb 2015 5:46pm
DMRR
Did he call my car FAT!!!?!?!?! Rolling with laughter Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #313715 19th Feb 2015 5:50pm
DavidL
Thanks. Not sure how it ended up here. Could it be moved to the general forum please.
Now I'm liking that. Question is for an 03 car is it expensive or should I really compare it to a 4.2s/c in which case its cheap.
Post #313769 19th Feb 2015 8:59pm
Welshdragon
Hmmm quite like that....5 ltrs...and on cheap tax been an 03 not the stupidly post 06 tax. If it dont work.......burn it!
Post #313775 19th Feb 2015 9:10pm
DMRR
I had a pre-stupid tax 4.2SC .... they are out there Very Happy Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #313804 19th Feb 2015 10:19pm
But what would you take the 580 S or the 4.2 SC Whistle ====================================
Post #313860 20th Feb 2015 12:22am
DMRR
4.2SC - more horses and better 0-60 ... oh and it's factory Cool Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #313861 20th Feb 2015 12:34am
The 4.2 Mick... The OF 500 has proved quite delicate with age Shocked
Think the crankshaft alone for that engine if north of £5K!!! Shocked Shocked Shocked
At least if the SC develops a fault, you could take it to any MD to have it fixed! The OF would be a nightmare if the engine went wrong!!! Whistle
Post #313862 20th Feb 2015 12:36am
Philip
Just a BMW S62 crank, nothing special.
Post #313864 20th Feb 2015 1:28am
Ahem... NO sir it certainly was NOT... Overfinch took an Ascari (S62) Crank and further enhanced it so NO NOT a standard S62 crank at all!
Post #313881 20th Feb 2015 9:47am
DavidL
Good as I was quite tempted! I like things a bit different and I can't afford a softdash LSE 570.
Clarkson mentioned a trick crank in the video so it must be true!
Post #313884 20th Feb 2015 10:13am
Philip
You could buy a custom billet crank for less than £5k. Not sure what you could actually do to it to make it that price, apart from mount jewels on it.
Edit - I will qualify it by saying you're obviously risking things not being easily sortable with something like that.
Post #313903 20th Feb 2015 12:16pm
DavidL
It seems the last of a breed - reworked engines by OF. And it does look smart.
What has been a bit fragile Craig?
Post #313907 20th Feb 2015 12:41pm
