Home > Technical (L322) > Air suspension
HGv driver
Wales
Air suspension
Getting message will lift when cooled any idea what's the problem folks?
Post #314506 23rd Feb 2015 6:28pm
the compressor is overheating due to it running to long, maybe due a leak somewhere?.. ... - .- -.
Post #314508 23rd Feb 2015 6:37pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
^^What he said; I had a small tear in a front bag Big Cry Big Cry
You can grip the wheel arch and lift slightly listening for a hiss.
I bought a pair of front struts (Delphi, not Dunlop)
Post #314518 23rd Feb 2015 8:13pm
Rovertech
United States
Re: Air suspension
See if you can find a fault code for c1A13-64 or c1a20-64, if you do, replace the compressor with an AMK. otherwise you can test for leaks with a roll of painters tape. Simply raise the vehicle to off-road height, turn it off and disconnect the battery. Then place painters tape on all 4 fenders extending down to the middle portion of the wheel, making sure it's tight. Then over 3-4 hours you will see where it's dropping. One corner means a bad air bag, one axle is a cross link valve block. All 4 wheels
Is a main valve block or reservoir. Generally speaking, and keeping mind that holes in air lines do occur, but not often. I have a rebuild kit for front air springs, and it works better than arnott.
Post #314977 26th Feb 2015 3:11pm
HGv driver
Wales
Thank you for you replays as this fault came up on my drive to work Monday ,will it be ok to drive it home Friday? Bristol to cardiff
Post #315006 26th Feb 2015 6:38pm
with out knowing what is exactly wrong its difficult to answer that . ... - .- -.
Post #315008 26th Feb 2015 6:45pm
