![]() | Home > Technical (L322) > Air suspention problem? |
Sounds like some air moving around in the system. If it is working fine with running engine and no fault codes I wouldn't worry about it too much.
x-box Member Since: 18 May 2012 Location: uk Posts: 76 ![]() |
that's a good excuse to give up!!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
That is normal behavior, the system self levels after you park, if you leave the ignition on it keeps doing it for a while, mine does it all the time when working on it, just leave a door open and it should stop doing it.... Pete
many thanks for this clarification, its good to know its a normal behaviour. |
Rovertech Member Since: 25 Feb 2015 Location: Seattle Posts: 20 ![]() ![]() |
+1 |
