Home > Technical (L322) > Left window open and then it rained!!
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Hi all, proud owner now of 2002 4.4 v8 vogue and whilst round a friends left the drivers side window open during a heavy shower! Front windows now won't work of drivers side switch pack, but do of remote ( eg holdremote to wind up). Figuring must be water in switch pack? will it dry out? Checked fuses and ok? Also sometimes both sides have mind of own and go down. ah joys of l322 ownership!
Post #27926 12th Sep 2010 6:57pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
watched the gadget show and they had a demo of drying waterloged electrics and the key was speed and drying out asap to get them working. would sugest you dry asap or get look for a new switch etc Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #27942 12th Sep 2010 8:29pm
Nickj
been a couple of days now so might be to late! Live in fifth floor flat so need long extension lead for my hair dryer. Hopefully a warm day today may have helped or will have to go somewhere with heat gun. Will it make a difference though and do i heat the swithch panel?
Post #27943 12th Sep 2010 8:34pm
iT LAD
You need this then....
[url] http://www.sailgb.com/p/12v_hair_dryer/
Post #27951 12th Sep 2010 9:31pm
dan_uk_1984
Go for a long drive, set the heater to max, direct air to the vents, close the middle vents so it forces all air to the side vent and point it at the switch pannel.
This should dry the switchpack out nicely. Make sure you leave the a/c on so that it can dehumidify the air.
And dont do it again. I once left the rear door open all night and it rained, luckily everything was OK though. At least rain is clean, its not like you've spilt a can of coke in there!
Post #27954 12th Sep 2010 11:34pm
iT LAD
it's odd that there is no alarm when you leave your window/doors open once you have turned of the car... or at least a option to.
Post #27961 13th Sep 2010 7:09am
Nickj
It wasn't locked as on friends drive as i was working on the car. Fixed one thing and broke another!! Will try the heater thing today. Noticed the wing mirrors not working also so must be pack related.
Post #28089 15th Sep 2010 10:57am
Nickj
On a positive note with a wipe over with a cloth it brought up the leather nicely!!
Post #28090 15th Sep 2010 10:58am
baz77
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Hi.
New to the forum,bought a 2004 R/R/Vogue 6 weeks ago,During the heavy rain about 4 weeks ago did the same thing,left the window open,about 10 mins later closed it and wiped all the water of the switch pack.Next day none of the switches responded,fuses o.k.As the car is under warranty took it to a approved garage,they checked it out and stated the switch pack was defective after being contaminated with water.They replaced it with a new one.This was about 10 days after the storm.Hope this helps.
Baz.
Post #28182 16th Sep 2010 1:08pm
iT LAD
Welcome baz77...
That was handy, getting it replaced....
Now don't do it again... Laughing Laughing Thumbs Up
Post #28193 16th Sep 2010 2:22pm
Nickj
Still no joy. Spent twenty minutes drying it with a hair dryer to no avail. Still no front windows or side mirror adjustment. Guess its a new window pack switch!! Also caused me some pain couple of days ago when windows came down of own accord and refused to go up the way i did it originally through total close button on remote. Stuck in public place with front windows fully down!! Couple of hours later let me use remote function to close. Electric gremlins joy!!
Post #28456 19th Sep 2010 2:41pm
Nickj
Is there a quick way to get the window pack out or is it door card off. any tips on this??
Post #29380 25th Sep 2010 6:47pm
baz77
Hi Nickj.
The guy who replaced my switch pack told me 3 screws and then the door card,and be careful near the door lock button.Hope this helps.
Baz.
Post #29426 26th Sep 2010 10:56am
Nickj
Fitted second hand pack and alls well. Note to self - Must not leave window open again when raining!!
Post #36582 17th Nov 2010 8:20pm
