Home > Technical (L322) > Select Neutral
dalziel
2003 Range Rover SE Td6 Epsom Green
Select Neutral
Just got car back from repairers after a rear end shunt. Foolishly only checked rear bodywork didn't think to start it up. Got in after delivery wagon had left and on start up it flashed "select neutral" and then when I tried to reverse out it flashed "slow down". Immediately thought of Low Ratio settings and tested selecting low ratio box. The switch does nothing. I select low ratio regularly so that was a surprise. Put IID Tool on: no faults stored. Turned off and started car again - exactly the same messages again. Wondering if driver tried low ratio to get on transporter and has ' Censored up' something. I am waiting for call back from repair garage. Any ideas on what it might be? Wondered about a fuse?
Post #316161 4th Mar 2015 4:38pm
mjdronfield
Is it fuse 37 that has to be in to force transfer box neutral?
Ie you need to remove the fuse to drive normally ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #316204 4th Mar 2015 8:33pm
mjdronfield
It is....
Not sure if the message on the instrument cluster is what you have though.
Hope you get it sorted.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #316209 4th Mar 2015 8:45pm
