Home > Maintenance & Mods (L322) > Oil change
comports
Oil change
Hi Folks - Just been told that to do an oil change on my 2010 MY the oil needs to be sucked out rather than warmed up and left to drain (like the good old days.!) Is that really the case?
Thanks Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #318251 16th Mar 2015 1:40pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
You have the choice of either ,but on a TDV8 their is two sump plugs.
Have a look at Wiki.
Post #318264 16th Mar 2015 2:46pm
ajac8
Nice wiki work.
I too am considering an oil change but like the idea of a vertical pump. Although its a D4 this vid is very helpful:https://www.youtube.com/watch?v=Wbftim2AR2w
I heard the sump plugs are not designed for regular use and can be easily mis threaded / worn but do wonder how pumping out removes all the crud from the sump.
I think a sump off every so often to clean the magnets and do a visual is ok but why get in such a mess using the 'old' method?
The pumps are easy to get hold of.
The other thing to bear in mind is that there is no dipstick on the 4.4 (the wiki is for the 3.6) so having an accurate (and clean) record of amount of oil removed means you can put the same back in!!
Anyone used these pumps on a 4.4 TDV8? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #318303 16th Mar 2015 7:14pm
Shocked there is no dipstick on the 4.4 Shocked
Surely this is fundamental vehicle check for the user or do LR offer lifetime engine replacements ? .
Post #318360 16th Mar 2015 11:11pm
Googsy
Lifetime dipsticks... Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #318363 16th Mar 2015 11:13pm
ajac8
The dipstick is virtual i.e. its on the service menu on the TFT display.
Pretty pointless if you ask me. I much prefer a mechanical thingy I can touch and check.
Back to my point about oil changes, at least with a dip stick you are not relying on a sensor to tell you how much oil is in the car you can use your own sensors located each side of your nose.
All the more reason to use the pump oil change method - at least you can put in the same quantity as you get out with no risk of over filling? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #318368 17th Mar 2015 12:11am
LR MD's only ever suck the oils out of 09> 322's as there is no access to the drain in the sump... 3.6's & 4.4's Neutral
Post #318371 17th Mar 2015 12:15am
silversurfer
I have two sump plugs on my TDV8 which is a 2010 REG, and the build date is 2010
Post #318520 17th Mar 2015 10:17pm
As do they all SS Thumbs Up
BUT, the subframe is in the way hence why LR dealers suck the oil out sir Thumbs Up
Post #318534 18th Mar 2015 12:53am
Arkle
I've been a sucker for many years and the oil is very clean. Even on a diesel, the oil is still golden in colour after 1000 miles if you get all of it out.
A tip I picked up just a few hours ago - After pumping out the oil to empty (as much as you can and then leave for half an hour to get the dregs) add 0.5 litres, wait... and then suck that out too! Its gotta be clean this way.
BMW have been "Suckers" for around 25 years now and Mercedes-Benz for around the last 20 years.
Just don't swallow. Wink Laughing
Post #318536 18th Mar 2015 4:40am
