Home > Technical (L322) > 'Hack' for TV/DVD on the Move: UPDATED
Page 1 of 3 123>
As these are often asked for I cut and paste them out, thanks mainly to Thrasher for this info.
I tried the '753' TV hack and have posted pics of the menus. These may not work on your car, some MY have different settings. Sorry about the picture quality, I blame the iPhone.
Most of the information is meaningless to us mere mortals but it does mean you can watch TV or a DVD (if fitted) whilst driving and can also enable the rear view camera on all the time while driving.
How To:
Start up DVD/Select TV Channel WHILE STATIONARY and engine on.
Press the top middle of the touchscreen when it is on the "home" screen for 5 seconds and release, then press the hard nav key for 5 seconds and release. Keypad entry will appear, enter 753 and OK.
Go to Audio Video settings and TV Video input
Press the Pal/NTSC to get the right picture type then toggle the size (Wide/Wide2/Normal to alter picture size.)
Here are all the screens available to you.
 Discovery 4 HSE
1993 90 Tdi
Post #19060 29th May 2010 12:34pm
NickH72
2007 MY and i dont get any menus come up when i try this!? The hard nav button i assume is the physical buttom on the top right?
Also sent me into some diagnostic screen on the Nav when i accidentally pressed that screen for 5 secs instead of the tv/dvd screen, how do i come out? or does it time out?
My guess is i am to blame! Smile
Cheers
Nick
Post #19217 1st Jun 2010 3:49pm
Switch it off, pull the key out, run away!
When you have the HOME screen up with the soft buttons for all the functions (Audio/Phone/Nav) etc this is when you first press and hold your finger on the centre top of the screen for 5 seconds.
Then release and press the top right hard button for the dat nav and hold it for 5 seconds. Then release and it should take you to picture number 1 above. Discovery 4 HSE
1993 90 Tdi
Post #19222 1st Jun 2010 4:43pm
NickH72
Thank you!.. it's ok, the car blew up 2 minutes later! Smile
So this isnt a permanent fix? i.e you have to do it everytime you might want the tv on the move?
Cheers
Nick
Post #19247 1st Jun 2010 8:19pm
Interestingly I was playing with this last night and although my TV picture is all-right normally in this test mode it's rubbish , also I didn't have to re-cycle the ignition to get out , I went in to revers to park and the reverse camera took over then it went back to the test screen so I pressed the Radio/Tv hard key and all of the functions came back . 2008 MY Supercharged
Post #19274 2nd Jun 2010 7:57am
TV is rubbish at first but if you press the PAL button it goes back to satisfactory. Discovery 4 HSE
1993 90 Tdi
Post #19275 2nd Jun 2010 8:24am
doublejay
No joy for me. 2005 with Touchscreen and MOST. plus 07-08 satnav disc upgrade.
I used be be able to get in with an older method, but that went with the Sat Nav upgrade it think.
Either, I spent quite a few lots of 5 seconds and can't get any joy.
Post #19369 3rd Jun 2010 11:32am
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Nor me??2007 MY Big Cry If you have nothing nice to say,say nothing at all.
Post #19399 3rd Jun 2010 6:14pm
adara
Thank you, it works! Maybe it should be mentioned that after pressing the touchscreen for 5 seconds, nothing shows up, you just go and press the nav plastic button for another 5 seconds and the keypad appears on the screen…
Post #20099 14th Jun 2010 4:40pm
yawlboy
United Arab Emirates 2009 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
works brilliantly, thank you
Post #20167 15th Jun 2010 9:53am
adara
A pre-touch screen friend asks if/how can this be done on his...
Post #20446 17th Jun 2010 5:47pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi Adam, I'm still not too clear on which menu I need to be in initially . On my touchscreen, if I turn the audio on and then select the DVD/TV button it will immediately put the dvd/tv on in the left upper side of the screen with the channels listed to the right of the display. Is it in this screen where I hold for 5secs? Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #20763 21st Jun 2010 6:19pm
Right here goes , and I'm rubbish at long explanations .
First with the engine on turn your TV on and showing ,next at the top right of the screen you can find a house shaped soft button ( its on many of the available screens) press this and you get a screen with soft button options of all the different screen functions ,Radio,Nav ,Off Road info etc.
Press and hold the top middle of the screen above the line for five second , nothing will happen , them press the hard Nav button for a further five seconds and the hack key pad will show , press 753 OK and Bob's your Aunties husband .
Hope this works for you . Thumbs Up 2008 MY Supercharged
Post #20785 21st Jun 2010 8:48pm
RRVSE
Hi Axle. Thanks for the explanation, I have now accessed the diagnostics successfully.
Strangely, the only thing I did different to the numerous other attempts was to do what you said and go into the TV/DVD first then come straight back out via the home key. Before I just went to the main audio menu ,pushed the hidden button for 5secs, but when I held the hard Nav button, it just brought up the Sat Nav, so going into the tv/dvd first does appears to be the key to accessing it (weird sequence). Maybe the others who have been unable to access the diagnostics were doing the same as me, mines a 56 reg so I reckon we should all be able to get at it. Ta. Very Happy Steve
Post #20812 21st Jun 2010 11:48pm
RRVSE
I find it strange that you can select 3 different screen formats for the rear view camera but they aren't a normal menu option? I quite like the 'wide 2' display format and I tried leaving the reverse camera on when on the motorway and it was actually quite useful to take a quick look when lane changing as it enabled me to see the blind spots around the 'd' pillars quite easily. Also, I did note that you can actually enable this whilst on the move (not that you want to really). Steve
Post #21527 3rd Jul 2010 6:48pm
Page 1 of 3 123>
