![]() | Home > Technical (L322) > Mettalice wrattle on idling |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Has any one had the following issue on a TD6 or other?
Yes that sounds about right - is there only one and are they easily accessible? CURRENT : FFRR 2012 4.4 TDV8
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
I think there are a few, but they are relatively easily accessible from underneath. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35795 ![]() ![]() |
stick the FFRR in 4x4 high mode and you can get under without creaking your neck .lol. ... - .- -.
Rangie in oz Member Since: 25 Jul 2010 Location: liverpool Posts: 52 ![]() ![]() ![]() |
Hi Guys, dont know if this helps but I have the same probs with my TD6, not there all the time but sounds like a very heavy tappet noise, or a loud ball bearing in an aerosol can, have had a couple of places look at it and both say nothing to worry about it.
could be a broken cat converter... ... - .- -.
Finally managed to have a look underneath once the car had reached temperature.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I had the same coming from the front of my TD6, turned out to be loose front brake, backplate/shield. |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
I remember having a rattle develop on my old TD6 for no particular reason - turned out to be the heat shield near the bulkhead for the exhaust downpipe had 'warped' and was touching the exhaust - must have been due to heat etc.
If your Metallica is rattling, turn it down OR replace the rattly speaker |
