Home > Technical (L322) > Drivers door lock FUBAR
GraemeC
My issues was the black plug into the door card.
If its the same as mine (2007) and the Powerful UK video, its the plug where you have to use a flat bladed screwdriver to unplug - 2min 15secs on here &feature=youtu.be 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #320678 31st Mar 2015 4:30pm
Paul_H
England 2005 Range Rover Vogue Td6 Tonga Green
I was doing a similar job this weekend and had exactly the same happen, disconnected the battery left it a while and then reconnected hey presto jobs a good un Wink 2005 Range Rover Vogue with Supercharged Accessories
GONE 2001 Discovery TD5 ES
GONE 1995 Discovery 300 tdi GS
Post #320779 1st Apr 2015 12:27pm
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Guys. Sorry to resurrect this thread.
I'd settled on it being the lock/latch and went Vegas with the intension of ordering one this weekend now I'm back.
Went out tonight to reset the service interval as I had serviced car myself a few week ago and have just realised not only does the drivers door not lock or unlock via keyfob or dashboard button, but also the internal door handle light isn't working or the puddle light anymore. All are only effected on this door.
Have tried the battery removal for 20 mins (is about all I can do in the dark) but am now wondering (again) if it could be electrical?
Could things be pointing to that large 4 pin plug you mentioned?
Does the big 4 pin plug that you remove with a screwdriver on the back of the door card, service the remote locking, puddle light and door handle light? Or am I just getting hopeful?
I really have tried connecting and wiggling etc it before and it seemed seated. Maybe try tomorow with the battery connected so I can see if it makes a difference?
Cheers
Tel Accept, some days your the pigeon, some days your the statue!
Post #322114 10th Apr 2015 8:27pm
GraemeC
I think your problem is with the connector, I was unable to source a wiring diagram, but remember my puddle light didn't work and the interior light would not switch on when opening the drivers door (all other doors worked fine)
I think the big connector supply power to the door latch assembly, hence it won't lock/unlock from the fob, but also the sensors don't register whether the door is open or closed, hence no signal to turn puddle or interior lights on
I would take the door card off again and try playing with the connector and measuring whether there is an voltage at the door latch assembly before ordering a new assembly 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #322130 10th Apr 2015 10:29pm
Boydonegood
Awesome. Thanks!
The interior lights are working as they should, but I'll have a good attack on it tomorow!
Cheers Accept, some days your the pigeon, some days your the statue!
Post #322131 10th Apr 2015 10:33pm
Boydonegood
Guys
Again I Bow down to your superior knowledge.
I had checked that large plug about 10 times so had settled on the lock u/s, but a new day and fresh set of eyes, a lot more wiggling of said plug (also a lot of swearing) and everything's come back to life!!
Thanks so much guys.
Really appreciate it Thumbs Up
Post #322163 11th Apr 2015 12:40pm
GraemeC
Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #322170 11th Apr 2015 1:57pm
