Home > In Car Electronics (L322) > Removing audio head unit
Zeus
Scotland 2004 Range Rover Vogue 4.4 V8 Java Black
Hi all,
Any tips on where to start when trying to remove the audio head unit in the dash? Or at least get to the wiring.
I have a bad (intermittent) connection on the screen and also now on the right speaker channel which I think is more likely to be in the head unit rather than the DSP in the boot.
Zeus 2004 4.4 V8 Vogue
Post #320823 1st Apr 2015 4:20pm
first 3 videos here,
https://www.youtube.com/results?search_que...ing+screen
and in this how to here,
http://www.fullfatrr.com/forum/topic29219.html ... - .- -.
Post #320826 1st Apr 2015 4:25pm
Zeus
Fantastic Stan,
Just what I need. Thanks
Post #320832 1st Apr 2015 4:56pm
Err...... You do know the radio tuner is in the rear compartment of the car.
I might still be looking for the bad connection in the rear compartment before accessing the head unit. Thumbs Up
Post #320835 1st Apr 2015 5:08pm
Zeus
No I didn't know that.
So which box actually produces the right speaker channel? I have lost it on the radio and the CD player and I guess sat nav etc but I don't actually use that.
I have lost the entire right speaker so that is low, mid and tweeter.
Post #320836 1st Apr 2015 5:28pm
The radio tuner is under the small floor panel in front of the rear recess. you need to lift the removable panel and then remove the panel tray below it.
The radio tuner is the silver box nearest to the front of the car and nearest the centre of the car ie in front of the tv tuner with the one large plug connector on the top.
The radio tuner also incorporates the system amp.
These cars usually suffer corrosion of the various components due to water ingress therefore I'd be inclined to work your way through all the plugs/sockets in the compartment one by one looking for signs of water damage.
You could initially start by looking at the other smaller plug on the top of the DSP with all the speaker cables on it.
It's also possible the DSP has internal water damage. Unfortunately they do suffer it.
Do one plug at a time and keep checking as you go along for any improvement in the sound output, you might strike lucky.
Tedious I'm afraid but anything you do will save doing it in the future.
One thing to look for particularly is when you remove a plug from a socket check that all the pins are still in the socket and that one hasn't broken off due to corrosion and is stuck in the plug.
This particularly applies to the pins in both of the smaller sockets, the speaker cables, on the DSP .
Post #320844 1st Apr 2015 5:56pm
Zeus
Thanks
Worked through all that, even removed the tuner and the DSP and had them apart on the bench. They look good with no sign of water damage.
Still the right channel does not work most of the time. sometimes works for a bit on start-up but then drops out after a variable amount of time.
Is there a schematic / wiring diagram for the audio system - I can't seem to find one in the manual.
Zues 2004 4.4 V8 Vogue
Post #320950 2nd Apr 2015 12:09pm
Pm me your email address and I will send you full wiring diagrams for the car.
Post #320951 2nd Apr 2015 12:11pm
Zeus
Thanks NDFI
All received and I have had a scan through. It is a shame they don't actually say what function each wire has. I wanted to be able to follow the Right speaker channel through the wiring.
I'll keep struggling on
Post #320958 2nd Apr 2015 1:21pm
Zeus
Update.
Pulled out the dash as well (I know now that the head unit is not actually responsible for producing the audio as the tuner and amp is in the boot) Wiggled stuff about but no joy there either. Worth a try I thought.
I suspect that something is wrong with the tuner / amp (BM54L322) or the wiring that connects it to the DSP.
Looked on eBay for BM54L322 - even if it's just to try for elimination purposes - a bit of a SHOCK on the going rate which seems to be £150 quid or so. One on there at £50 but it doesn't work!
I shall just drive with the left channel for a bit while I figure out what to do.
Thanks for all your help. 2004 4.4 V8 Vogue
Post #320971 2nd Apr 2015 3:19pm
Do you have the original telephone in your car and does it work?
Post #320972 2nd Apr 2015 3:24pm
Zeus
No, It seems it was never fitted with the telephone option - just an aftermarket Parrot. 2004 4.4 V8 Vogue
Post #320974 2nd Apr 2015 3:31pm
Ok Thumbs Up Mine was and it caused a problem.
If you have a need to get your BM54 repaired / refurbished Baris, a member on here does a very good service.
I used him for mine, really good.
He can be contacted by email........ xkalibar@gmail.com or .... navicars@gmail.com
Post #320976 2nd Apr 2015 3:42pm
Or junk the whole, unreliable, outdated lot and fit something that works.... Whistle Whistle
http://www.fullfatrr.com/forum/topic27033.html Pete
-Click here for Thread-
Post #320985 2nd Apr 2015 4:28pm
mjdronfield
Get the stage 2 bm54 amp upgrade from Baris. It will fix any channel issues on the original amp and double its output, along with better quality sound. Get in touch with him and have a chat.
The end sound result is cleaner than on the later cars with the so called better systems in.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #321004 2nd Apr 2015 5:55pm
