Home > Technical (L322) > Bong - abs, hdc , no suspension , and locks up !
barwik
United Kingdom 2003 Range Rover HSE Td6 Buckingham Blue
RR Nearly locks up !!good evening - Anyone experienced this one - as its get more frequent.
My recently acquired 2003 TD6 is great BUT - I can be driving along and the Hdc light comes on along with abs,traction control and brake warning lights - the suspension de-activates as well .
It may do it again next trip or it might be 2 days later .
But now when I set off it wont pull away - it feels like the brakes are on , if I take my foot of the throttle it immediately stops and is then fine - 300 yards later the dash lights up .
If I drive slowly the abs kicks in -slight pulsing from the brake pedal .
I've plugged it in and it faulted the n/s/f abs sensor - replaced this but symptoms are the same .
Anyone had this before ?
thanks in advance
john
Post #320883 1st Apr 2015 8:40pm
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Similar to my mates car. It was a leaking
brake pipe. We fixed the pipe and all the
other warnings stopped. Worth a look.
Good luck
Post #320891 1st Apr 2015 9:00pm
Mr Tee
Mines the exact same, currently getting the o/s/f hub stripped to see if the reluctor wheel is still there or has corroded away. Sensor checked , working ok, just not getting any signal pickup. Expecting a wallet rape yet again!
The dsc will trigger above 5 mph , if you continue trying to drive, the faults will flash up but the car can continue to be driven, just the systems effectively non operating , mine keeps telling me to select neutral for the hdc.
Post #320906 1st Apr 2015 11:01pm
mjdronfield
It was the reluctor ring on mine. Though I also had speedo not working as mine was passenger rear......
http://www.fullfatrr.com/forum/topic20879.html?highlight=reluctor
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #320914 2nd Apr 2015 5:53am
barwik
plugged it in and I've replaced both front abs sensors - both looked ok and the o/s one even looked like it had been replaced before - BUT - been several weeks now and it aint done it since .
Various other faults have come to light - not related but that's for a different post .!
Post #325849 3rd May 2015 8:27pm
