Home > Technical (L322) > Pdc sensors?
William97841
Pdc sensors?
Right got a problem with my pdc on l322 td6 vogue just simply their not automatic when you put it in reverse but work perfectly fine when you push the P button works as good as gold but they don't come on when in reverse is that right?
Post #320896 1st Apr 2015 9:09pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi
Rears should come on with reverse - unless you have trailer connected. Fronts only come on when button pressed. (stops them beeping when in traffic!!)
Cheers
RP
Post #320928 2nd Apr 2015 8:52am
Not quite , Front and Rear both come on when reverse is engaged OR the button is pressed , unless there is a problem , which there usually is Laughing 2008 MY Supercharged
Post #320942 2nd Apr 2015 10:42am
William97841
Well I know for definitely the the button/sensors work when the buttons pressed but when reverse is selected they don't come on so much dunno if that's how they should work?? Rolling Eyes
Post #321043 2nd Apr 2015 9:39pm
