![]() | Home > Wheels & Tyres > Stormer reps won't sit on hub correctly/studs dont line up |
Evoque fitment? |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
nevermind...got it. They just take a lot more wrastling to get them on |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
If they're that tight I'd put some copper-slip on the central spigot to make sure you can get them off to change a wheel by the side of the road |
I know plenty do it and most get away with it but lubricating the mating surfaces of your wheel and hub removes the friction holding the wheel in place . The wheel nuts pull the wheel in to create this friction and should not be relied on to take the weight of the vehicle as they can fail under the shearing force .
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1868 ![]() ![]() |
The wheel nuts clamp the wheel to the hub. The centre spigot is only to hold the wheel central, to prevent any unwanted wobbling caused by an uncentered wheel |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
I would personally not feel safe and happy with that situation.
The centre spigot is there to take the weight NOT the wheel nuts!!! They are to hold the wheel on... Hence you have Spigot rings to make sure wheels fit on hubs! |
I thought that was a given, Craig. Evidently not.
Just making it crystal clear for members, the importance of centre bore/spigot fitment rather than PCD etc sir... |
well even the stockers have to be muscled on and wiggled about to fit against the hub perfectly. These just needed even pressure (a little more than stock) to push it against the hub and get the nuts on which was a little tricky with 1 set of hands. I will say even the stock wheel is a bit of a pain to line up right to get the nuts on...not only do you have to fit the studs on the holes but there is wiggle room where you need to rotate the wheel while on the studs to get the nuts to go on the bolts correctly. Never had a car that was so temperamental with putting wheel/lug nuts on |
