My guess would be the ignition switch itself, it's got a mechanical part in the bottom that makes the connection when you turn the key, these are known to wear and fail on the earlier cars so I suppose as the later ones age it could happen as well, you don't need the whole switch, just the bottom part of it so you keep your key and barrel, well, that's if it's the same as the earlier ones....
It is only a guess, could be a poor earth, ignition relay, immobiliser or some other ECU fault.... Pete
-Click here for Thread-
