![]() | Home > In Car Electronics (L322) > How to make sat nav voice louder ? Stop echo on stereo ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
you can increase the ladys volume by pressing the up button on the steering wheel when she is talking...
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
For sat nav sound level select "set" on home screen, select "Navi Volume" and adjust as you require.
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 ![]() ![]() ![]() |
Thanks for the tips.
Postcodes are added to the MK4 discs by way of an "Extra". I have it on my disc and it's as good as Tomtom.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
"Jazz Club" .............. Nice! .
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
@Zambesi - If you have it set to "Jazz Club" perhaps you could ask them to stop playing for a moment while "she" gives you the next instruction...? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8752 ![]() ![]() ![]() |
Mine was doing the same as yours, I tried every button I could find to turn her up but nothing worked... I decided there was a fault somewhere..... another reason for changing to the Android setup.... Pete
Thanks for that. I've PM'd Baris to ask about the discs, and await his response This is the one I bought separate to buying the Mk4. The "label" full 5 or 7 postcode digit postcode functionality by as I said I can usually only input a max of 5 digits and then need to select a road form the list which doesn't always work for Suffolk at least. The disc label also mentions the need for 4-1/00 software to make full use of the DVD functionality but I don't know what my 2002 head unit would be and whether it's possible to upgrade the software ??? I know that I have a TomTom but would like to get the factory fitted SatNav as good as possible Cheers David 2002 4.4 V8 with LPG Zambezi silver |
Arkle Member Since: 17 Aug 2014 Location: Cheshire Posts: 173 ![]() ![]() |
Yep, just marry it. |
