Home > For Sale & Wanted > [For Sale] Fancy learning plc programming? Home automation f
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Thought id give it a go on here, its on eBay for 1k, forum member can have it for 500 quid.
This is a steal really, I use one at home for my pond, garden lights and central heating.
Can be used for home automation or any thing you really want. I can give pointers and advice if required. This unit would require an expansion module for temperature.
Mitsubishi Beijer E910T touch screen and a FX1S PLC module.
These are in perfect working order. Screen has a few scratches from use. The screen has been fitted with a new power supply.
Comes with all you see in the pics inc cab19 for connecting the screen to the plc.
No programming cables are included. You will need to get these, and the software, I can help if required.
The plc requires 240v supply and 240v for the inputs and the outputs are 24v.
I have put in a very simple program to test it and so that the buyer can prove its operation out of the box.
This is a technical piece of kit and requires electrical and plc knowledge. The item if fully tested and working and I cannot be held responsible for damage due to incorrect wiring or misuse.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  You remind me of a young me, not much younger mind, perhaps even a little older!
Post #340509 3rd Aug 2015 9:06am
