![]() | Home > Maintenance & Mods (L322) > ticking noise behind dashboard |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Had the same thing some time ago... It turned out to be a parking ticked inside the heater motor... I removed the final stage resistor to have a look inside the heater motor.. I was able to remove the parking ticket from there..
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
The big black electrics box in the engine bay is ventilated into the cabin area behind the dash area.
Does the sound increase / decrease when you manually adjust the fan? 2002 L322 V8 |
tevista Member Since: 20 Sep 2014 Location: paisley Posts: 16 ![]() ![]() ![]() |
No , its only when u unlock the car and wake it up . Lasts bout 20 secs then all quiet . |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
Had exactly the same thing recently. Turned out it was a broken blade on one of the fans in the heating / ventilation system under the dash.
It was the motor for the footwell blend motor. It was turning further than the flap was able to, it could not be recalibrate do and was replaced.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
Sometimes my car also does some noises when I turn the key.
