![]() | Home > Technical (L322) > bulb warnings |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
i'm using the fog units for drl's so i have the two fog supply wires on each side doing nothing ,so is there any way of 'fooling' the bulb warning by fitting a resister or joining the wires together... ... - .- -.
And the reason using fog lights in clear conditions is illegal is ? |
This makes me |
to avoid any more sad faces this is what i'm doing....
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
"236
read my post carefully sir... ... - .- -. Y. O. L. O. . |
You'll have to ellaborate..... have you removed fogs and replaced with driving lights (DRL'S)? |
i've re-designed my setup...
iT LAD Member Since: 08 Jul 2010 Location: Surrey Posts: 1350 ![]() ![]() |
Scarey, you trying to upset people again... |
It's not like him ............ |
i like me lights.... |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi, i understand what you have done, the fogs are no longer fogs but are led driving lights that dont project light that far at all, not to stop the warnings you need to fool your lcm in thinking the bulds are still there, this is dont by connecting a resistor between the live and neutral, this allows just enough load to fool the lcm that the bulb is still there, V8 facelift Range Rover Autobiography 22" wheels.
Just one question Scarey..............Why? |
