![]() | Home > Technical (L322) > Reliabilaty issues on 2012 model year FFRR Vogue TDV8 4.4 |
Was that a miss type? TDV6 FFRR sir |
| Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277
says TD6 Vogue in his signature, so i would say so. |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
My 2012 Westminster (25,000 miles) has had:
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
Flippin eck CS you got a Friday afternoon car there by the looks of things. Glad to see the warranty has come to your aid. I do second the paintwork on the lower tail gate issue. Mines a 2011 MY and disappointed to see it starting to bubble only slightly for now.. Other than that I've had no issues but I've only had the car 6 months. Just about to break 80K and going smooth.
| RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398
Hi,
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
It's amasing isn't it.... my 2003 has absolutely no rust on either tailgate and yet time and again we see these posts about cars 10 years+ younger... what have they done, added salt to the paint!!!!! Pete
Ford took over in 2005 Pete... |
| CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685
I've had my 2010 MY 3.6 TDV8 for 6 months and I've had no problems at all |
| Diver Bryn Member Since: 16 Jan 2012 Location: Durham Posts: 34
Sold my 2005 (Purchased from new) TD6 Vogue with 150K on Clock and absolutely brilliant mechanically. Rust blebbing through rear wheel arches (even after LR replaced the rear offside wing under warranty) Replaced front air suspension arms x 2 and normal service cost's. Looked at replacing it with Tourag's, XC90's, ML's, Audi's Q7 and yet nothing comes remotely close to the Rangee luxury, by the time you build other manufacturers products up to same Range Spec! Now on route to look at striking a deal on a 2014 TD6 Vogue new shape. Happy days! Diver Bryn
| stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188
Turbo drain pipe modification.
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818
Nothing other than the tailgate bubbling rubber window trim - best car I have had ! (So far!!!) 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
| cloudwind Member Since: 01 Nov 2011 Location: Hertfordshire Posts: 20
Same as previous poster Vogue with the rear screen trims, no big deal. Also had a drive belt pulley making a noise which was duly fixed without issue under warranty by Lookers Bishops Stortford. Thumbs up to them
Out of interest how did the gearbox failure manifest itself? I thought these new 8 speed gearboxes were fairly robust? |
What happened is that about 2 litres of gearbox oil leaked form where the gearbox and engine meet. The gearbox had continued to work as normal but LR decided that it should be replaced, perhaps because the loss of fluid might make it uncertain whether it would be OK in future. Only Range Rovers since 1988 |
