![]() | Home > Technical (L322) > Occasional power loss after long drives 4.4 (petrol v8) |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
I had similar on a Mini some years back. Turned out to be a blocked breather in the petrol tank. Try releasing the petrol cap after a long drive and listen for the air rushing in. You may be getting a partial vacuum in the tank. |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
if you are talking about engine power loss, then maybe your fuel pump is low on pump pressure. there are a few threads on this, sometimes, it just has no 'pedal power' other times it will (when cranking) -spin over and not start.
| heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170
most likely fuel pump.
| Bstrong Member Since: 11 May 2015 Location: United Kingdom Posts: 5
Thanks for all the suggestions guys.
