Home > General > Why are parcel shelves solid?
Zirconblue
The retractable cargo nets are often described as a retractable dog guard (it will serve either purpose), the same as they sell the metal dog guards and describe them as cargo guards.
What makes me laugh with the retractable net though, it Land-Rover sell it as an optional extra for £250. Whereas Citroen used to supply them as standard on the C5 estate! It's unlikely the LR ones cost significantly more to produce.
Post #327682 13th May 2015 2:38pm
mjdronfield
I'm still struggling with the idea some of you guys actually put stuff on it Shocked
Mine is ivory and I don't even like fluff on it.....
You'll be using it as a van next Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #327725 13th May 2015 5:25pm
Mines ivory and regularly has a dog on it Laughing
They come up quite nicely with a pressure washer Thumbs Up
Post #327773 13th May 2015 7:46pm
mat777
United Kingdom 2005 Range Rover Vogue 4.4 V8 Giverny Green
Mines ivory too but already rather grubby so I don't care.
The dog nets sound interesting, a friends bmw has one and it is very useful. Does the net canister simply clip into a slot behind the back seats or does one need to buy fixings for it too? NW060
"Red Shed" - 1982 Series 3 88" County Station Wagon
"Spirit of Great Britain" - Rolls Royce Meteor V12 engine
ZG875 - Westland Sea King (cockpit section)
"Carly Rae Jeepsen" - 2006 Jeep Commander 5.7 Hemi
"Pride Of The Road" - 1/4-scale Marshall traction engine - sold
"Georgina" - 2000 Discovery 2 TD5 ES - sold
"Windsor" - 2005 Range Rover Vogue 4.4 - dead
Post #328039 15th May 2015 11:28am
Weegie
You'll have the RSPCA after you. Rolling with laughter John
GAP iiD BT-Sold
Post #328042 15th May 2015 11:34am
Before I had the dog, I kept mine in the car, but put a black towel on the top so I could put stuff on top without marking the material.
Since getting a dog mine is never in the car, it's sealed up in the loft as new, ready for when I sell the car! Discovery 4 HSE
Post #328043 15th May 2015 11:53am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
@weegie Rolling with laughter Bow down
I quite like having the shelf to be honest. useful for the Costco run for kitchen/toilet roll. took it out when I too 3/4 tonne of plasterboard and plywood to the tip. Laughing
I definitely notice the increased noise when it's not in. I can actually sometimes hear the compressor when everything else is quiet.
Post #328053 15th May 2015 1:05pm
Requires fixings - sits behind the rear headrests & directly on top of the parcel shelf - retractable & has mountings in the sides up by the roof.
I had one on my L322 VSE & it was perfect for me - but they're not an option on the L405 so have had to go with a semi permanent metal mesh guard Big Cry
Post #328063 15th May 2015 2:12pm
Zirconblue
The kit comes with the brackets, if you look at the font ends of the plastic vent bits that the parcel shelf fits on you'll see some pop out panels where the cargo net brackets go into.
I think the top moutings are already there on all cars with a plastic flap over them.
Post #328125 15th May 2015 9:40pm
Rockingdodge
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
The clips are already there in the roof in 2 places in case you have the seats down for a large load.
I had to replace the plastic lugs on my shelf, probably through the previous owner/s put too much heavy stuff on it.
Post #328754 20th May 2015 12:34pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Same as HM1978 - I use the upper shelf also for kitchen roll, boxes of crisps etc bought at Costco and for putting dry coats on. I suppose they could do with a retracting cover, but one that runs in grooves on either side of the car (much like those covers you see people retro-fit to pick ups) and so could be strong enough to support light loads on top of them still. but that can also be removed as normal when folding seats down. I must say, the hard shelf is definitely classier, I've had 4x4s with roller covers and they always look like an afterthought in my opinion and some also seem to sag down after a few years (as the recoil spring start to weaken due to use I assume). Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #328784 20th May 2015 4:37pm
