Home > Wheels & Tyres > Narrow tyres !!
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Narrow tyres !!
OK so rather than ask the usual question of how wide can you go, I thought how narrow can you go?
Just got myself some 19" that I will use during the summer and thought about some winter tyres for the 18" I had on originally.
Been reading the handbook and it suggests a 235/65/18 for winter use - Seen some Vredestein Wintrac 4 Xtreme at £60.00 (plus delivery and fitting) and thought this sounds like a plan.
Has anyone done this? I can understand the logic of having a narrower tyre (more weight/pressure) on a smaller contact patch would help in snow etc.
Guess i would have to be less enthusiastic driving when the weather is good - but I'm at that age when that's not a problem Wink
Or is it best to keep it at 255/60/18 ?
Cheers
RP
Post #329024 22nd May 2015 10:48am
You'll see all sorts of advice on winter tyres......
Narrow is better for cutting through snow, but will be worse for stopping on a cold damp road.......
I've always stuck to standard dimensions - as I figure it has to be better from an insurance perspective.
Post #329035 22nd May 2015 12:23pm
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
235/65/18 Vredestein Wintrac 4 Xtreme is an excellent choice for winters Thumbs Up Supporter and maintainer of EDF - Mrs Edfors' shopping cart.
Post #329050 22nd May 2015 3:10pm
^ And he should know...... Thumbs Up
Post #329053 22nd May 2015 3:36pm
Rangeyman
Used to work on a farm in the 80's and 90's at 1200ft when snow was bad most winters and the best motor by a long way was the boss's Hilux fitted with Tractor tyres,truely amazing just how far that would go!!
Post #331408 7th Jun 2015 6:59pm
Zirconblue
Bit noisy on the motorway though and the tread flies off Laughing
Post #331410 7th Jun 2015 7:10pm
Rangeyman
Just used it for the milkround locally but getting back to the top of the hill up through fields when roads are blocked ,Priceless!!
Post #331565 8th Jun 2015 7:53pm
