![]() | Home > Maintenance & Mods (L322) > Should I touch it??! |
Yes its advisable to use them on a monthly basis but............. If you haven’t used them in a long while then they could move half way between high & low and stick your transfer box in N |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
And to your future secondary issue, air con should really be on all the time to keep the seals lubricated so the gas doesn't seep out.
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Doh!!
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988 ![]() ![]() ![]() |
"And to your future secondary issue, air con should really be on all the time to keep the seals lubricated so the gas doesn't seep out."
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276 ![]() ![]() ![]() |
From the owners handbook: "With the vehicle stationary and the engine running, apply the foot brake and then move the automatic gearbox selector to the ‘N’ (neutral) position before moving the transfer gear switch fully rearwards. When the switch is released, it returns to the default position." Operate the switch again to return to High range. Pretty much "literally sit in neutral and flick the switches" ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
Problem is that even though you got a new gearbox, they probably won't have changed either the transfer box or the shift motor - nor tested them |
The hill descent will work in high or low, so you can try that without worry. It uses the abs system to keep the car stable and below a set speed when descending. You leave the foot brake well alone during these slippery declines, unless you want to stop when back on level ground of course....... Touching the brake stops the hdc.
Ah cheers guys!
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
And it doesn't need to be run 'all the time', so long as you switch it on and run it for a period, say 20 min or so, every month or couple of weeks. AC also dries the air too though, so it will stop it misting up in there if you leave it on all the time. It's a little like electric cooling fans, they don't get used during the winter, so when summer comes you find they're seized up, the same can apply to the mechanical parts of the AC system, if not used for months they get stuck. |
Low range basically gives you access to an extra set of gears. (your car actually has 10 forward gears and 2 reverse) They're intended for hauling heavier loads and moving off on very steep gradients. Think of the range changer as being like the front set of sprockets on a mountain bike, a bike might only really have 7 gears but the 3 ranges on the front make it 21. You'd only really use the smallest front sprocket for really steep hills. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8787 ![]() ![]() ![]() |
Use mine when towing, regularly. The bit that fails is the electrical contact ring in the shift motor, peeps were trying to source the part a while back as the shift motors are silly money.
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 ![]() ![]() ![]() |
What? Air con on all the time so gas doesn't escape? Are these luxury cars actually rubbish or what, my 94 toyota Celica air con hasn't been recharged since I bought it in 2007 and although I rarely use it it still goes as cold as your freezer when you need it. Dan
I'm told by our AC man that refrigerant has changed dramatically over the past 10yrs meaning it is now far less polluting & poisonous when it escapes but, the downside to it is, it has a shorter lifespan especially if not used regularly...
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Not quite right Mark, with the HDC you can control the speed the car will descend by using the brake or the accelerator, leave it alone and it picks the speed, sometimes this is too low or too high, gentle braking will reduce the speed and accelerating will increase it, It works up to 35mph in high box... If you ever do a hill climb that you think may not work then you can engage HDC before going up, it will drive normally until it senses you are going down hill, so you can drive up the hill OK but if you fail and stop then a quick change into reverse and take your feet off and it will control your decent backwards, this is a great feature as it stops the front wheels locking and the car spinning sideways and then rolling over back down the hill... When working it makes quite a grinding noise as the pump works the individual brakes, it doesn't sound good but is quite normal... The later face lifted cars are even better, you can control the speed of the HDC with the cruise buttons... When HDC is working it puts on the brake lights to let followers know.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
