![]() | Home > General > Transmission durabillity due to different driving styles |
The ZF transmissions are not the problem in the FFRRs. The GM transmission in the TD6 (and other cars / brands) of that generation. I wouldn't worry about it, just drive the car the way it is meant.
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
They are probably good transmissions, the issue is the torque converters i belive wich are to weak for theese heavy cars am i correct?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8752 ![]() ![]() ![]() |
One of the worst things that can happen in owning a car is lack of confidence in the vehicle, it then effects just about every aspect of owning it....
Ofc you're right! Thanks Pete |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It also seems most of the weak points on these, gearbox, diffs, cooling system, electric fan are all the BMW parts. Just think, you could have bought a BMW, which was ALL made of BMW parts. |
Yes but it wouldn't be nailed together by as communist in Solihull |
