![]() | Home > Maintenance & Mods (L322) > Westfalia Clunkety-clunk! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
Not really - the 'quick release' Swan neck unit still has 1 bolt through the armature in the same place that the farmers one has a pin or bolt. It gives the illusion of security, but in reality is exactly the same - one bolt and you're away...... |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It depends which farmers hitch you compare it to.
I guess that ultimately, the Farmers - like 50% of the towbars in the UK can have the tow ball removed by the 2 bolts - and then reconnected to any other vehicle designed to take a standard EU tow ball.....
exactly, it's a question of making it worth their while for them to go and find easier pickings. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
If they want it they will get it. The lock won't make any difference they will quite easily get through pretty much any hitch lock.
