Home > Off Topic > Don't let them tailgate you |
dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014 |
L322 brakes are 100% BMW but LR would only issue a recall after a few deaths I'm sure.
1st Oct 2010 8:56pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Except the Bembros! |
1st Oct 2010 9:05pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
1st Oct 2010 9:11pm |
The only reason I'm not worried is because the X5 isn't listed under the recall. The front and rear subframes plus associated bits are off the X5 with only minor adjustments. |
1st Oct 2010 9:20pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
L322 Range Rover doesn't have the same engine as 5,6 or 7 Series V8's does it, they were 4.8's IIRC - also only 11000 cars including all Rolls Royces are included that wouldn't be enough cars if all V8 Range Rovers were included would it? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
1st Oct 2010 10:01pm |
Erm. Yes. The 4.4 BMW M62 engine is the BMW Engine of choice in the 5 series, 7 series and X5. Also the Morgan Aero. Our engine comes in a 3.5, 4.4, 4.6 and 4.9 varient. |
1st Oct 2010 10:14pm |
There hasn't been any mention of Range Rovers or Morgans made in the press, maybe there is some modification made to the LR versions to make it more suited to offroad use that means that RR's don't have the braking problem. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
1st Oct 2010 11:29pm |
I didn't say there has been. You wanted to categorise them by their engine though. Which has little bearing on their brakes.
2nd Oct 2010 12:25pm |
