![]() | Home > Off Topic - Other Cars > What is wrong with this tyre? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Had it been whacked into a kerb head on? It looks like the bead or the cords sidewall have been damaged. There is nothing that can't be fixed with a hammer😜😜
Have a wee shifty through this .... probably as N.M .J says
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Yes kerbed and unsafe, bin it |
Thanks for the replies and for sure, I knew/ know the tyre is U/S and it is already off the vehicle. I was just curious as to people's thoughts based on how out of shape it is as to what might have caused it as it has not been kerbed or subjected to any obvious impact (the outer facing/ wheel face aspects of the wheel and tyre are unmarked and look perfectly shaped).
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1400 ![]() ![]() |
IF you're SURE it hasn't been curbed or potholed get it back to the dealer as it is most likely a manufacturing fault , they will be interested as there may be a batch with the same issue , tyres should not look like that without accident damage or manufacturing flaws |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16394 ![]() ![]() ![]() |
+1 for the above... Have the manufacturer look into it Ryan |
The fact there are two quite obvious defects, almost 180 degrees apart, i.e. on completely opposite sides of the tyre would mean 2 impacts. So unless you've come across 2 kerbs about 18 inches apart I suggest that's more likely to be a manufacturing defect. It's hard to imagine any other explanation really so definitely take it back. |
Hadn't noticed the damage was on opposite side as well. I would get the selling dealer to look into it as it is probably as Dom says it's probably a manufacturing fault. They should replace it foc, as it is a fairly new tyre! There is nothing that can't be fixed with a hammer😜😜
