Home > Technical (L322) > Rear offside window working intermittently. New regulator?
Flashman
My rear offside window works sometimes and then other times does not react to any of the window switches (or key remote). It seems to get better in summer which makes me think that it could be something to do with the motor/regulator in the door freeing up with warmer temperatures and jamming up and tripping the anti trap sensor in winter.
I have checked the window for any debris or blockages and it looks clear.
Before I strip the door down, has anyone got any other ideas on what could be an issue, and is replacing the regulator/motor assembly a straight forward task? Tom
Current Drive
Previous Drives
Post #331142 5th Jun 2015 3:52pm
Flashman
Guess nobody has had a similar issue.
Hope replacing the motor/regulator is not too complicated in practise. Tom
Current Drive
Previous Drives
Post #332154 12th Jun 2015 9:09am
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
How did you get on with this issue?
I've got a drivers window that opened but wont close via either switch on door or key fob and wondering if the regulator was the cause you found?
Post #540839 17th Jan 2020 8:09am
andyfid
England 2003 Range Rover Vogue SE Td6 Tangiers Orange
Try unplugging the switch in the rear door I have just had problems with the switch not working and the front switch didn’t work as well but when I unplugged the rear one that was faulty the front worked again
Post #540960 18th Jan 2020 8:09am
fenlander
Interesting thanks, I'll check out my other doors via their respective switches (don't know if the rear ones work by that method as rarely use them)
Does the GAP IIDTool give any useful troubleshooting info I wonder?
What you describe is exactly the issue I had with a 2002 Zafira many years ago and they were German motors too Smile
Post #541041 19th Jan 2020 4:04am
