Home > In Car Electronics (L322) > Ignition switched power feed
apole
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hi,
Trying to find a switched power feed for my camera. Would normally use an add a circuit or solder into an appropriate feed.
Was thinking to use the sunroof feed to reduce cable run but don't think that is a good idea given how thin the wires for that are.
Looked at fuse box behind glovebos but quite restricted access and not neat to run wire from front due to cover.
Anyone have a suggestion?
Thanks in advance.
Andy
Post #331606 8th Jun 2015 11:02pm
apole
Sorry guys, just found this, should have searched more thoroughly before asking.
http://www.fullfatrr.com/forum/topic23389.html?highlight=dash+cam
Post #331613 8th Jun 2015 11:21pm
The vanity mirror lamps are ignition fed sir Thumbs Up
Post #331614 8th Jun 2015 11:26pm
