![]() | Home > Technical (L322) > Where does this pipe go? |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
I've just changed my air con pipes and I spotted two vacuum hoses hanging. One I found out connects to a black plastic cylinder mounted on the inner wing but I can't see where the second one goes to
| Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912
Not off the Black plastic accumulator that sits to the top left against the suspension turret. I think it's to do with the vacuum for the turbo, sorrhy not in car so cant go and look.
I think I've worked it out.
Sounds right. If you want me to check I can look at mine later unless someone has a picture handy. Mine was a blue one! |
If you could, I'd be grateful. I phoned the dealer and he seems to think it's right. He did confirm that with a disconnected vacuum, it would overboost and over-fuel, causing the engine knock. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
