Home > General (L405) > 5.0 SC Driving Differences
Page 3 of 3 <123
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
if you want to pull away faster hold the brake with left foot then press right to 1500ish revs then let go if you want to pull away quicker, the tuning boxes i believe take a lot of lag away as my old td6 had one no probs for years but no idea if there reliable enough for new models _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #332814 16th Jun 2015 9:12pm
CEEGEE
Sounds like a great way to break something to me Whistle
Post #332838 16th Jun 2015 10:19pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Tried switching auto terrain to manual road and it does feel a bit better but doesn't allow setting off in 1st on mine (didn't turn off traction control) so perhaps their is an update that changes it do drop to 1st?
Deffo better though.
I've been in discussions with Blue Spark about their top box that does fuel and boost, their guys are very helpful, very knowledgeable and the box comes with a no quibble refund if I'm not happy so I might try one, its easily removed if I change my mind.
The L405 SDV8 is a good car, I'm getting 33mpg from it with a mix of spirited and standard driving, just want a bit more response low down then it will be a very good car for me.
Its in to have the suspension checked on 30th because its knocking so with that sorted it will be a great place to be and a great car to own
Post #332867 17th Jun 2015 8:02am
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Cannot recall trying the foot on the brake from low down but all modern LRs are remapped so you cannot do this in certain circumstances, (it used to be a way of getting heat into the brake pads during bedding in). I'll try the sc later. I'm a left foot brake merchant but because I've been driving a manual car a lot recently I'm not doing it all the time in the FF.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #332868 17th Jun 2015 8:06am
carlos50
I'm not sure I like the idea in truth, launch control in a FFRR Laughing
Post #332869 17th Jun 2015 8:25am
Paul J.
^^ try 'sand mode' if you want a quick getaway!
Post #332886 17th Jun 2015 10:21am
Nick Ground
Quick check on the way to work confirms that above 12mph the throttle is disabled when braking. Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
Post #332903 17th Jun 2015 12:16pm
Page 3 of 3 <123
