![]() | Home > Technical (L322) > Tdv8 turbo failure |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Ta Craig😁 There is nothing that can't be fixed with a hammer😜😜
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Oh Craig, come on! We all know that you enjoy carrying out a good tranny service whenever you can..... ![]() 2019 Renault Zoe Dynamique Nav ![]() |
GrantMundy Member Since: 12 Jun 2015 Location: Berkhamsted, herts Posts: 12 ![]() ![]() ![]() |
So.... We were looking at it last night, and we decided just to drop the whole lot out the bottom, was going to be easier than splitting the box and engine, and much less of a fight to remove the turbos. Found out it is the drivers side turbo that has eaten itself, so they will both be off to the midlands on monday |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Any thoughts on what caused them to fail? ______________________________
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Why the moderators pic Scot |
Out of interest, What leads you to believe they are both broken? |
I believe both, as one the exhaust housing is full of oil, so that there is a pool of it sitting in the bottom of the turbo. And the other turbo, the impeller shaft has oooodles of play, and the intake housing is full of oil. More so than the other side.
Out of interest, do you have a map on the car? There is nothing that can't be fixed with a hammer😜😜
I don't, no. Not mapped, completely stock |
So a seal failure or shaft wear, or both? Are they able to be refurbed?
What sort of mileage are you on? There is nothing that can't be fixed with a hammer😜😜
I'm not sure what's caused it to be honest, think it wasnt short of oil. Could be wear, and one was leaking, then when the other gave out it had nothing?
That's not mega mileage
