Home > Maintenance & Mods (L322) > Interior light removal
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
Hi guys,
I've started to replace the interior lights with led's but am struggling with some.
I've done the load space lights ( had to replace a fitting as I broke a clip.( Thanks Dan) I've also done the front interior light and the reading lamps. I then tried to do the dash end and mirror lights having read on here how to remove them, or so I thought.
I got the dash end off but couldn't get the light fitting out and I also couldn't figure out the mirror.
Can anyone point me in the right direction with some tips. Mine is a 2007 by the way .
Thanks.
Keith
Post #332801 16th Jun 2015 8:48pm
Fish
No tips guys?
I did read that if you take the dash end off you can get your hand in to release some clips on the knee level round lights but there is no way to get my hand in, I can barely see the fitting at all.
Surely these bulbs are replaceable, do I have to take the lower dash panel off?
Thanks
Post #333031 17th Jun 2015 10:35pm
Zirconblue
The round dash end lights, you pop the end cover off then just twist the light fitting and it comes out, didn't seem especially difficult when i changed the bulb in mine the other day.
Post #333037 17th Jun 2015 11:14pm
Fish
Thanks, I think yours may be different then mine. Are yours in the same piece as the vent? Mine are in the plastic part where the airbags are and I can't even see it through the end.
Post #333140 18th Jun 2015 3:15pm
Zirconblue
Probably yes, the earlier ones like mine the lamps are in the Wood veneered bit under the vents.
Post #333186 18th Jun 2015 7:35pm
Fish
Part way through now.......
I managed to get the round dash light out from behind with a plastic wedge and a small screwdriver at the front.
I figured out how to remove all the grubbing to do the passenger side and also managed to replace the glovebox light which has never worked. Both front door lights and the footwell lights have also been changed. I just need to figure out the mirrors now before I move into the back.
I also changed the sidelight builds because they looked a bit blue. I was jutting putting grill back in when I noticed the cap on top if the engine Censored so had to take it apart again.
Post #333737 21st Jun 2015 1:32pm
schan51
United Kingdom 2008 Range Rover Vogue SE TDV8 Santorini Black
hope someone can help me with instruction on putting back the front interior light and the reading lamps
I've taken them off today to replace one of the bulbs and now the whole casing doesn't sit back in properly
The inner black casing clips back in ok, but the outer casing doesn't want to sit back in correctly
any sort of help is very much appreciated
Post #336914 11th Jul 2015 8:44pm
supershuttle
I liked em blue !! Geoff
Post #336918 11th Jul 2015 8:50pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Have a look at the metal prongs, some times they get a bit bent as happened on my rear one.
Just might need straightening out Thumbs Up
Post #336956 12th Jul 2015 6:58am
Eirik34
Norway
Re: Interior light removal
Fish wrote:
Hi guys,
I've also considered replacing the interior bulbs with LED's, but thought it couldn't been done due to the dimming of the lights. Where did you find the LED's that works with the dimming of the lights in the ffrr?
Post #336970 12th Jul 2015 9:54am
the main lights will dim if replaced with leds...
see here,
http://www.fullfatrr.com/forum/topic25268....ior+lights ... - .- -.
Post #336971 12th Jul 2015 9:58am
Fish
Hi, these are the various bulbs, mainly following advice by Stan and others.
http://www.ebay.co.uk/itm/400429616363?_tr...EBIDX%3AIT
http://www.ebay.co.uk/itm/391135689226?_tr...EBIDX%3AIT
http://www.ebay.co.uk/itm/310359392661?_tr...EBIDX%3AIT
They make a huge difference to the interior Very Happy if you put them in they only work one way round so make sure you check the light works before you fasten it back in position.
Post #336972 12th Jul 2015 10:03am
Fish
Sorry Geoff, nothing wrong with the blue as such but thought I try them more white Embarassed
Post #336974 12th Jul 2015 10:05am
