![]() | Home > Technical (L405) > Active Rear Locking Differential. |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 ![]() ![]() |
I had this option on my SDV8 as it seemed good value, 'For refined traction and cornering stability'
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
Should help to tighten the line under power. |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
It's great off road. All FFRRs have a centre diff. However, if one front or rear tyre looses traction, it will spin while t's mate just sits there, doing nothing. This diff will lock automatically when it senses wheel spin, providing drive to BOTH rear wheels. You don't need it often, but it's great when you need it. It's a LOT more user friendly than winches, sand ladders, etc. I have one on my L322. It's not a common option, but I think it's standard on the Supercharged. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8798 ![]() ![]() ![]() |
The torsen torque splitting center diff can distribute power between 65% front, 35% rear to 35% front, 65% rear, the axle diffs then take over, if one wheel starts spinning the TC cuts in and brakes that wheel sending power to the one that has grip.... result..... you move again....
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 ![]() ![]() ![]() |
Sorry to dig this thread up, but am I right in thinking, this option on TOPIX basically means no active rear diff;
ilard Member Since: 21 Oct 2012 Location: London Posts: 715 ![]() ![]() |
I have the active locking diff and it says:
Perhaps if you say what vehicle you are looking up on Topix... |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 90 ![]() ![]() |
Correct. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
You could have a look to see if there's a motor on top of the diff to be sure. |
Sorry yes its a SCV8/P525
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Not a standard fitting on the SDV8 either chaps.....
Standard in SDV8 from MY2017 onwards.
