![]() | Home > General > Has anyone got an Ifor Williams trailer and Farmers hitch |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
I've got one of the large Ifor car transporters, and I've got the tow ball in the top holes on my farmers hitch. |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
I'd like to see what type of farmers hitch you have - mine only had two sets of holes (Westfalia).
Yep, top set of holes for my GD105 as well. |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
Again, top set of holes for HB511 and GD84 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8093 ![]() ![]() ![]() |
Another vote for top
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Excellent will move the ball up before i go.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
I know it won't help the OP but may help others. I tow ifor tri & twin axle traitors both are tilt beds and you can adjust the bed to suit (by closing the tilt bed on a spacer bar and extending the lock bars a turn or ten!) that way we can have the trailer perfectly flat on a detachable tow bar...
Does that adjust the wheels too though? Although mine isn't a tilt bed, I was more concerns about the wheels being on the ground evenly. If it's nose down then the front axle could be over loaded while the rear is only just touching the ground. |
Yes, that's exactly what it does... As the bed tilts, even by half an inch it lifts the wheels that end by 3 or 4 inches... Hence levelling the trailer to your car... |
Unfortunately the tilt bed system only applies to transporters and not to flat beds (LM series) or horse boxes (HB series).
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
Need to watch the back bumper using the top hole - some hitches get very close with the factory ball. |
You're right there - you need the Westfalia extended ball suitable for stabilising hitches |
When you say transporters... I presume you mean car transporters? Mine is the farmer type flatbed with sides and a tilting hydronic bed for easy loading of sports cars... ![]() |
