![]() | Home > Technical (L322) > Air Suspension inactive |
| PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877
You need to get the fault cleared by a diagnostic machine. |
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591
What does it do when you ask it to change ride height? |
| leedslad Member Since: 09 Mar 2015 Location: leeds Posts: 10
It Does nothing no lights at all |
No lights at all on the centre console ride height button? Have you done a lock to lock since new compressor fitted? |
| chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130
Turn the steering wheel lock to lock. |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
As Paul said, the fault is called a "hard" fault, you can't clear it unless you have a diagnostic tool even if you have fixed the problem... most garages should be able to do it but tell them your not paying if they can't clear the fault....
Pete this was the OPs sentence I was alluding too, I have had the air suspension inactive warning a few times which were incorrect and were a battery issue, |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
As Paul above said, if you had air sup inactive on display before you changed the compressor, the suspension would of locked up in normal hight and to re set you will need diagnostics tool like iid to clear the fault or faults. If it dont work.......burn it!
yes had inactive before changing compressor
Yep..... message alone and normal lights on or with the lockout led in the height switch lit and the battery procedure will do it...
Or drive over here and I can do it for you.... Pete
Cheers Pete when's best to come over |
| Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267
Yes it happened to me when I removed my compressor,no lights at all,fortunately my mate called and sorted it for me with a plug in.Ps,i managed to sort my compressor with the piston ring kit for £20 !!! |
I'll PM you.... Pete
| All times are GMT |
