Home > Off Topic > Tax and PAYE
Tax and PAYE
Hi
Im after a bit of info. Can anyone tell me how this paye works? I get overtime so my monthly pay changes a bit. This month ive had my bonus which is a 15month one. This looks to have taken me into the next tax band. Will the tax be adjusted next month when i get back to my normal pay or will i get a rebate at the end of the year?
Thanks [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #334482 26th Jun 2015 7:31am
mzplcg
OK, the 2 basic principles are very easy.
1. Tax is cumulative fro the year
2. NI is not cumulative.
Taking income tax first, broadly speaking the payroll software will take the free pay (up to 10600 for most - just add a zero to your tax code) and divide this by 12 (assuming you're monthly paid). You get this amount tax free each month. Then it takes the next band (up to 32010) and divides that by 12 which is what you pay 20% on. If you happen to make more than this in a given month then you will pay 40% on the remainder up to the 150,000 threshold which I assume you aren't going to hit.
Then if you have a standard month next month where you don't use up all the allowance for the 20% band the software will take the bit you paid 40% on in the previous month and set it against the unused part of the 20% band in the next month so you get a 20% tax refund (effectively meaning the 40% bit will be tax free) on that bit which you paid 40% on. i.e. The Payroll software will work in a cumulative way so that come the end of the tax year you are all square.
NI is different. It works in a non cumulative way. You have the lower earnings limit £111 per week, or £508 per month) and you pay NI on everything over that at 12% up to the upper earnings limit of £805 per week or £3690 per month. Over this you pay 2% NI. But it's not cumulative so if you don't use you free pay (below the LEL) one week it does not carry over.
Hope that helps. If you need more send me a PM and I can give you my wife's email - she is Payroll Manager for a large firm and CIPP Masters qualified in Payroll and pensions. Thumbs Up
Post #334486 26th Jun 2015 8:19am
Thats great thank you. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #334490 26th Jun 2015 8:40am
dingg1
BUT if you break the 100k threshold you lose your personal allowance
Post #334491 26th Jun 2015 9:07am
mzplcg
Erm, that's 120k, not 100.
Post #334495 26th Jun 2015 9:42am
dingg1
You're correct . my mistake Embarassed
Post #334500 26th Jun 2015 9:54am
Do you instantly loose it or is it evaluated on your P60? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #334516 26th Jun 2015 12:36pm
mzplcg
Neither. The "Free Pay" element of your salary is controlled in the payroll software by your tax code. The HMRC tax office would have to issue your payroll department with a new tax code for you, the payroll team would have to change this on your record and then you would lose allowances (free pay)
So, technically speaking, from the RTI (Real Time Information) which your payroll department submit to HMRC when they run the payroll each month it is possible the Tax Office would pick this up and issue a zero tax code. If this happened you would have to call the Tax Office and explain the situation after which they should issue the appropriate tax code for you.
However, in real life the Tax Office are not as efficient as all that (understated diplomatic version) and by the time it was picked up it would be several months down the line when there have been further RTI submissions to level out the bump caused by a one off bonus payment.
BUT.!! If it genuinely would send you over the £120k annual limit for that tax year, and it wasn't picked up, and you didn't notify the Tax Office, you WILL end up with a tax bill to pay the £10600 (or whatever your tax code is) at 40%, so £4240.
Post #334537 26th Jun 2015 2:16pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Really? not for me or others I know in this bracket. As you approach the £100k threshold you have to start making some proper financial plans. The gap from 100 to 120k is where the PA erodes. Best course of action to protect income is to pay anything over £100k into a pension. That goes in gross and you get taxed at a lower rate when you eventually draw your pension.
Post #334614 26th Jun 2015 9:44pm
dingg1
Thats what threw me , and thats exactly what I do , get it in the pension and retain the personal allowance.
I think for every £2 you earn over 100k they take £1 off your allowance until you hit the 120k then the lots gone (in simplistic terms)
Post #334645 27th Jun 2015 8:40am
Andy S
We're both on the same page then Ding.
Post #334743 27th Jun 2015 7:22pm
mzplcg
No, the threshold is 120K according to SWMBO. 119999 and you retain the allowances, 120k and you lose it. It also includes stuff like car allowances so if you get 8K car allowance the threshold is reduced to 112k.
But as said above, easier to shove it in the pension, especially if your employer matches your contributions which a lot seem to do. That doesn't count towards the 120k limit.
Post #334745 27th Jun 2015 7:44pm
Andy S
Sorry, you're mistaken. I know, because I fall into that income bracket, that your personal allowance reduces by £1 for every £2 of income over £100k. HMRC even tell you on your notice of coding. The affect is for those who earn between £100-120k pa their marginal rate of tax is over 60%. That's why it's better to pay into your pension and keep the full value of the PA. Once over £120k you have no PA but your marginal rate drops back to 40%.
Post #334768 27th Jun 2015 10:18pm
Andy S
And your car allowance is not allowed against it. Mine counts as part of my gross pay.
Post #334770 27th Jun 2015 10:20pm
