![]() | Home > Technical (L322) > Should the electric fan stay on with engine off? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
it might be faulty.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
Hi Zircon,
Is the temperature gauge going too high? |
If stopped in heavy traffic with lots of stop starts it does start to increase to 3/4 of the dial with no noticeable fan noise kicking in. When this has happened I have put the heating on and it then reduces the engine temperature as it sucks the engine heat into the cabin.
Exactly.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8781 ![]() ![]() ![]() |
The electric fan doesn't come on until the engine gets very hot, it is variable speed and at it's lowest it is difficult to hear, this speed is usually enough to cool the engine. It won't work with the ign off, it draws a lot of current and heat soak would make it come on a lot and it would flatten the battery.
Thanks Pete, much appreciated info. I will check it out. Tom
When it's on full chat you can definitely hear it. I had the opposite issue, fan would come on for no reason and flatten the battery. it is predominantly there to aid the air conditioning and generally only comes on to cool the engine when the gauge is approaching the red section.
Have you tried sticking the AC on? The elec fan will come on with the AC switched on so well worth checking that works first, then when it gets warm, switch the AC on! Or as most do, run with the AC on auto and let it take care of itself |
Thanks for the advice guys. I will try the AC to see if it gets the main fan to kick in.
Just started up the car in the 23.5 degree heat, put the air conditioning on full cold and full fan speed and the front fan behind the grill is still sitting there doing nothing. I will give the car a bit of a run this afternoon and keep an eye on it. Looks like my fan is not working. I will check the wiring and then look for a replacement.
