Home > General > Lower half detailing...picture heavy
First post so here goes.
Bought a 2002 TD6SE a few weeks ago after owning a Classic for a number of years.. The paintwork and interior of the TD6 was in dire need of some tlc as the previous owner was of the horsey or farming variety.
I have detailed the paintwork but am struggling with the plastic area at the bottom of the doors which seem to be almost impossible to get the scratches and swirls off so any advice gratefully received. Thumbs Up
Here are some before and after pictures
This is the plastic area at the bottom of the doors
Almost a half a day later and there are still marks that seem to be impossible to remove
Post #30860 5th Oct 2010 11:27pm
RRCanuck
Canada 2010 Range Rover Supercharged Supercharged Santorini Black
Super job compared to the orig picture Thumbs Up
mb.
Post #30863 6th Oct 2010 1:40am
thats a proper job mate, how did you do it? ... - .- -.
Post #30877 6th Oct 2010 9:17am
Paulo
Looks great so far, see your Machine polisher is getting a good work-out... Laughing
Loved the work Dave & Gordon done on your Rover on DW...
Hoping to join the RR fold soon myself... Keep up the good work... Wink
Post #30902 6th Oct 2010 10:08am
Vogue
looks fantastic Thumbs Up
I also have problems with swirl marks in the lower panels - I think it is something to do with the material and paint. Being GRP (or similar) perhaps the paint is softer ??, its really odd because the body panels polish up nicely yet the lower door panels still have imperfections and no matter how hard you try they won't come out.
Mind you as they are the lower panels and reflections off them don't catch the eye as they are angled slightly downwards I don't feel that it really matters Rolling Eyes I've got bigger body imperfections to worry about - caused by branches, mud, fences and podgy tummy... Laughing
Post #30909 6th Oct 2010 10:19am
iT LAD
Yes, a fantastic Job. Thumbs Up Thumbs Up Thumbs Up
Post #30911 6th Oct 2010 10:21am
I use a rotary polishing machine to remove the worst of the swirls and marks. The vehicle was washed then clay-barred and washed again, then Farecla G10 cutting paste was applied by machine before applying A Grade Polish again by machine. Once this was done the whole vehicle was again polished with A Grade by hand so remove any minor marks and get into the corners the machine misses. Next two coats of wax are applied to seal the paintwork from the elements.
Post #30977 6th Oct 2010 1:43pm
mzplcg
Assuming you have the Makita type (or clones) of polisher - 9 inch grinder style.
Menzerna orange pads.
3 or 4 spots of pad lubricant (Gloss-It Pad Prime)
some Menzerna SS100 polish (one grade more aggressive than regular 3.02)
Because the panel is plastic it can heat up very quickly which isn't good as I'm sure you know Wink
Work the machine at low speed (900rpm) as if you were spreading the polish but keep working it at this speed rather than using the zenith method to break down the particles. Work large areas at a time so there is plenty of cool down time between passes. That's how I did mine and they came up a treat.
You can then finish off with some Menz 85RE for a deep gloss.
Top job BTW. Thumbs Up
HTH.
Dom.
Post #31047 6th Oct 2010 5:37pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Cracking finish 47, do you do outcalls? I have a Def90 that needs the same treatment................... 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31048 6th Oct 2010 5:51pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
try this too
http://www.meguiarsdirect.com/product_detail.asp?T1=MEG+G1016 2002 td6 vogue, 06 supercharged facelift
Post #31081 6th Oct 2010 8:07pm
