![]() | Home > In Car Electronics (L322) > Bluetooth for L322 2006 RR Vogue |
maddirk Member Since: 01 Jul 2015 Location: Chart Sutton, Maidstone Posts: 15 ![]() ![]() |
Dears,
There is a lot of info on the BT units here. Easiest is to send a picture of the rear compartment to Wiggins and see if he can help you. He does BT exchange, basically getting you an updated software unit that works better than the original |
Hi, yes, I checked and could not find any cables with connectors that were not connected to something. D |
Thank you, I will do that, perhaps he may be able to help! D ![]() |
Just fyi, here are the pictures. No Bluetooth or phone gear, or is there?
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
unit at the top with multi colored cables and two thick white ones that are fiber optic. Thats your BT module |
Thanks, mate! But I don't get any "Land Rover" bluetooth signal, what's wrong? And if I press "Telephone" on the console, it just says "not installed".. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Try the secret codes and turn it on there. In the wiki I think. Link is top right of main forum page. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Probably too obvious but have you tried pairing your phone? John
Thanks, I could only find secret codes up to 2005 models, none for the 2006 L322. |
Yes, cannot get any "Land Rover" appearing on my phone when scanning (engine running). |
My goodness, I am a complete |
Here we go again. Audio bluetooth is not working. I'm sure there's a threat out there for the best solution, but if you could point me to it, please? Even just an audio jack mod would be fab...
