Home > Maintenance & Mods (L322) > V8 viscous fan removal tool
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
hi mate, i thought britpart parts had a standard 2 year wotsit?
http://www.britpart.com/about-us/24-month-guarantee/ 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #335587 2nd Jul 2015 6:51pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
The one I was replacing wasn't a Britpart one, the new one is.
Post #335630 2nd Jul 2015 10:41pm
87RJD
Morning all
I'm going to change both belts on my car 4.2 S/C, before I start:
1, Can anyone confirm if a normal 32 mm spanner will fit the viscous fan?
2, Is it possible to improvise holding the fan, or is there a readily available tool from Halfords etc.
Any advise before I start would be appreciated. Land Rover wanted £465 to supply and fit, I bought the belts for £90 the pair (Genuine) so happy to plod on for a day if it saves me this amount,
Thanks SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Triumph TR6 1973
Triumph Bonneville 1970
Previous:
2002 TD6
Merc SL500
Escort RS Cosworth
RR 3.9 Vogue
4.2 E type Jag replica (challenger)
Escort RS2000 (many)
Escort RS 1600 Turbo
Post #351175 8th Oct 2015 9:06am
johnboyairey
im not familiar with this engine, however, the same proccedure to many similar engines, would be, to draw a diagram first, and take a few pics, of how the belt is threaded etc. as it can be very confusing when the belt is off, as to how it goes back on! its usyally a case of flexing a small damper that applies spring tension, (an idler pulley) and pulling it off there, then releasing the tension. then belt is removed, then threaded back on, and a spanner is used to re-spring the tensioner, to allow it back on, and released, confirming, that the grooved belt is indeed on the same groove on all pulleys. normally, you can start car up to check its running right, and inspect, with torch, with the fan off, for a minute of two.
you could search the web, for a photo'd proceedure, as engine is same as jaguar version? i believe.
£465 Shocked jeez, that must include his fine dining, in his lunchbreak as well.
Post #351177 8th Oct 2015 9:35am
