Home > Technical (L322) > EGR valve removal
Dolphinboy
EGR valve removal
one for you technical types. what are your thoughts on removing the EGR (Exhaust Gas Recirculation)? I have heard tell that it makes the valve and associated solenoid chamber fill with cr4p, and removing them increases power since only pure air is then introduced into the cylinder.
What neg effects might this have on the engine?
Post #31002 6th Oct 2010 2:52pm
If you remove the EGR valve it will affect the MAF and cause the vehicle to go into limp home mode. Best to clean it out and refit it.
There is actually a way to remove them but you have to let the ECU think that it's still connected
Post #31034 6th Oct 2010 4:29pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Proper blanking kits are available too, from BAS, one of the forum sponsors on our sister forums RRSport.co.uk and Disco3.co.uk I don't know if they sell them for TDV8's but I know that Pete of BAS is familiar with the engine so I'm sure it won't be long before he has one! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #31043 6th Oct 2010 5:21pm
