![]() | Home > Off Topic - Other Cars > Found this ....any ideas? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Yes it a differential gear, with its crown wheel. it's definitely not limited slip so,it's worth very little, you could count the teeth, and research with a certain matching pinion gear, it's turning ratio, that might be a start, but if it's was used, and you had no idea of its model, it would be worthless, unless you were reading a newspaper in a gale.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Don't know it's size but could it be from a tractor? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35779 ![]() ![]() |
could it be this,
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 309 ![]() ![]() ![]() |
Thanks for all the help, I'm still unsure as to what it is exactly for so I've donated it to someone who may make use of it, shame to bin it. |
I think Stan is right.... |
