Home > Technical (L322) > Front Noise Back Noise | L322 2008 RR Vogue
luv2xlr8
United Arab Emirates 2009 Range Rover Supercharged 4.2 SC V8 Bournville
Hi All,
Yes, me again with some more challenges, already... Rolling Eyes ..I have searched the forum and couldn't find anything.
Front Noise
Recently replaced my front air struts assembly and noticed when driving, a really weird SHHHH noise from the front right of the vehicle arises. Noise happens when accelerating between 1K - 2K RPM , at higher speaks it goes away. No Power loss. Sound can be replicated. Sometimes the noise disappears but then comes back to annoy me again. While i've explained the sound to sound like SHHHHHHH, it can also be referred to as taking a hot pot of the cooker stove and placing it on cold water SHHHH…but its more of a build up noise then builds down, so higher and lower depending on acceleration style.
Dealer said they will have to check it first. So when collected the vehicle, went for a spin with the advisor and said could be a seal or gasket or something loose forcing in a wind noise? He also noted, Insulation.
Blower is fine as the noise comes when AC on or off.
I also had a AC gas refill, could the mechanics have forgotten to close down something leading to the noise?
Im so worried and hope not another Censored …..
Rear Noise
This is referring to the cover. Not the net covert, just the cover that slides open and closes. I sat in the back while a friend drove the vehicle and noticed how depending on the road conditions, the cover tends to move from the middle and make an awful rattle, What the best way to tackle this? What should I use?
Help Please?
Post #336022 5th Jul 2015 9:43pm
Front noise sounds like a loose induction pipe or split pipe
Rear noise, use some sticky back foam to dampen the cover.... Pete
-Click here for Thread-
Post #336025 5th Jul 2015 10:25pm
luv2xlr8
Done with the rear noise, good fix.
Please could you elaborate on the induction pipe, location, exact area from the part thats possibly loose? Can I tighten it my self? Screw, Hammer? Very Happy …Car still running fine but that noise is so damn annoying. Hope its nothing serious.
Thanks Haylands..
Anyone else experience this before, please share and help?
Post #336707 9th Jul 2015 10:42pm
rar110
Check all the air pipes and tighten with screwdriver if loose. ______________________________
Post #336859 11th Jul 2015 11:37am
luv2xlr8
Thanks will check and have a look!
Post #337149 13th Jul 2015 12:59am
