![]() | Home > Technical (L322) > TRANS.FAILSAFE PROG |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
welcome to the forum dimi...
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Hi Dimi
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Dimi, it could well be your radiator is blocked at the bottom and the gearbox oil cooler is affected. Maybe investigate changing both at the same time? |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Second dolphinboys suggestion, change the main radiator and the gearbox oil cooler. Early l322's had a problem where the bottom 6 rows of the radiator collapsed internally and restricted the coolant flow to the gearbox cooler, causing an overheat and the Texans failsafe mode. |
| Dimi Member Since: 10 Jul 2015 Location: Bratislava Posts: 2
Hi guys
| All times are GMT |
