Home > General (L405) > Front parking sensors
J600.COM
One of the things I find annoying on the RR is the front sensors don't come on automatically. What I mean by that, is you seem to have to manually turn on the sensors - on my Mercedes they're on all the time which is far better. Is there a setting to permanently turn on the front sensors?[/i]
Post #337552 16th Jul 2015 8:41am
if its the same as the L322 then no , you have to engage reverse first or select it manually..basically this is stop the fronts going off automatically in traffic jams etc.. ... - .- -.
Post #337555 16th Jul 2015 9:13am
J600.COM
ah thats a shame. my front's do go off at traffic jams on my merc, but only when im about to crash into someone - so its still a good thing Smile even in my nissan there was an option to turn them on or off, wonder why they don't give you the option?
Post #337556 16th Jul 2015 9:44am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
This is another reason why I wish there was an access to all these settings, with a return to factory button. I only want the sensors when I want them back and front, like I only want the mirrors to fold when told. All such functions just need a spotty teenager to sort the algorithms, there is no on going cost
Far cheaper than adding bling and a lot more use. letters not necessarily in the right order
Post #337558 16th Jul 2015 9:48am
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hold down the parking sensor button for circa 5 seconds. The fronts will then come on automatically at low speeds.
Post #337562 16th Jul 2015 10:39am
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Autobiography, thanks for that. I wondered why my second L405 had the sensors on at low speed, the first and current only when button pressed. Is it the same to return from auto?
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #337576 16th Jul 2015 1:14pm
J600.COM
Do you mean each time you want to use it, or to enable / disable it being automatic when approaching traffic? On mine I can either select it manually by pressing each time (like literally turn it on every journey) or it kicks in once I've been in reverse.
Ideally I want it on all the time - is that possible? Keeping the button pressed in didn't do anything on mine, but I didn't know if you had to be in a certain state first (e.g in park, or on a certain screen on the dash?)
Any help would be great as id love it to work like my merc does
Post #337579 16th Jul 2015 1:48pm
Nick Ground
My last L405 had the front sensors on whenever coming to a halt. So no need to press buttons at each start up.
55 D3 SE
98 MX5 1.8 RS
Post #337584 16th Jul 2015 5:35pm
Classic Matt
An old thread but I'm very thankful for the advice - my other cars have had automatic front parking sensors so until reading this I thought those on my L322 were broken!
Post #571768 3rd Nov 2020 9:37pm
