![]() | Home > Technical (L322) > Trans Fail Safe - Gearbox issue |
Pepi Member Since: 04 May 2015 Location: Doncaster Posts: 125 ![]() ![]() |
Pete AKA Haylands
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1030 ![]() ![]() |
That’s a very specific fault. The only time I’ve seen that one before is when I repaired a forum member’s transmission and the screw holding the speed sensor retaining plate in place had come loose.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
that RRphil, he's the man!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8778 ![]() ![]() ![]() |
I have had the pleasure of seeing his man cave and I can confirm it is cleaner than an ISO1 clean room, it is truly a sight to behold... Pete
belldarr Member Since: 14 Jun 2014 Location: Bucks Posts: 149 ![]() ![]() ![]() |
Thank you Phil, that is a brilliant reply and really helpful.
Just to update this post and help anyone else that gets this problem.
Wow, that's a result Darren, glad your sorted, we're lucky to have Phil... Pete
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
@RRPhil |
